2500 front spring removal
Finally got myself a Kore hp suspension kit and will be putting it on any day now. only question i got is can i get the front springs off by just dropping the axle down far enough or am i gonna need some spring compressors?
I was wanting to ask some advice in which lift kit to put on my 99 2500 Ram.
I want a spring lift and not a spacer lift I want some good articulation and am looking to lift the truck 4-6 inches. I looked at the Sky Jacker double flex kit. Does anyone have any experience with this lift or any other lifts that would serve my purposes?
Thanks
Thanks
Welcome to the site.
You are going to want to go over to the 2nd gen section, as that is the type of truck you have. You will also want to start your own thread on this, as apposed to throwing it in any given thread.
Also do some searching, as there is probably many threads out there about this.
