cold is killing my ram
the antifreeze was in the truck from the factory...the chevy has never had it changed or flushed in the 8 years i have owned it. if dodge is charging 25 bucks for a jug and is the best they have for my truck...should i look else where for a diff kind?
no i do not think they have a life time antifreeze but i would think it should last more than 7 years...but i guess not.
i am scared to death of fails on the dodge. i have had in 40k miles both diff changed 3 times and transfer case and the trans mission fluid . a tune up new plugs and so on. i spare no exspense in doing this...mean while the chevy has just had the oil changed and is out living my dodge in repairs. i guess i will add to the list antifreeze every 5 years. seems things are not made like they used to be.
As for never changing differential fluid in your Chevy and changing it a few times on your dodge... Your chevy likely has wear inside there. it's made of the same components and metals as the dodge. You are doing what's called preventative maintenance. Just because the chevy hasn't dropped it's nut yet doesn't mean it's not on it's way there.
BATTERY, Optima? What kind? Red? Take it back and replace it. The Red's are NOT meant for everyday vehicles and especially not for a primary starting battery. They are deep cycle batteries that provide current for extended periods of time. They do NOT provide good cranking power for your starter and are NOT meant for cold. Not only do they provide barely enough cranking amps to start your truck, when they get cold, the cranking amps diminish rapidly.
Yelowtop? These are designated and labeled as being both regular and deepcyle in one. There is really no such thing although the Yellow's do much better than the reds for a primary battery. They still suck in the cold compared to a normal battery and they will not last as long if it's your primary battery.
T/B issue, Your lightning bolt caused by "freeze over"...... If you start your truck up and let it warm up for 15minutes and the light doesn't go out, then that is not your problem. There is a TSB regarding problematic throttlebodies in the cold just as you described. The only remedy is replacing the unit with a new one. I see them for sale on Ebay for fairly cheap. You need 2003-2004 as the 2005+ have a different pigtail connector.
There have been a couple of us from North Dakota that have had issues with the TB not working correctly. (he posted on the fourm also). I myself have had 1 problem with the malfuntion. I just strayed seafoam Deep clean in the air tube and I haven't had any problems since. I was also told that you can try and clean the TB because they get dirty. in the dakota's we get wind constantly (extremely dusty condtions).
since i sprayed the Seam up there I haven't had any problems, but we have only hit -20 once this year so far.
Honestly, I'm shocked your Chevy coolant has not caused major issues. There are more lawsuits filed regarding failed GM cooling systems than Ford, Dodge & Toyota combined.
http://www.consumeraffairs.com/autom...m_dexcool.html
http://www.girardgibbs.com/dexcool.html
http://www.stevesnovasite.com/forums.../t-128547.html
http://www.dexcoolsettlement.com/
http://www.vnnforum.com/showthread.php?p=995363
And regarding paying $25 for a jug of coolant. Just because the dealership sells it AND charges 3x for it than a good quality, name-brand sells for in WallyWorld, don't mean it's any better. But even at $25 a jug, is that a lot to pay for cooling system maintenance even if you have to do it once every 3 years? I flush and fill my radiator every 3 years regardless of mileage and have in all my Ford, Dodge and Chevy trucks I've owned for the past 26 years I've been driving...
Yeah I wasn't thinking about that. He did state he's never changed the anti-freeze in that '95 either. Good thing he doesn't own a '04 Chevy truck or he'd be on his third radiator, evap and heater core and probably second engine by now, LOL...
http://shop.advanceautoparts.com/web...1373081032___#
this is the battery i got..start fast and strong. i have had boats and the blue top deep cycle. this is a starting battery . seems to work good to me.
after i drive the truck it seems to run fine after a while. acts up after driving and letting it sit in the cold.
the radiator and water pump are being replaced. i will start changing the radiator fluid every 5 years. as i keep up with all maintance on the dodge.
the chevy i got for $1000 and got it before my ram. only thing i have done is oil changes and tires. starts runs and pulls just fine with out all the upkeep .if it dies it dies . but seems unstoppable even in the cold.
seems you have to stay on top of the recommended upkeep from the dealer on the dodge or you will have problems . or maybe it has a hard time handling the cold?
Have you checked around the intake manifold for air leaks? That would be a cause of it running like sh*t when it's really cold outside until the engine bay temp comes up...
It's been -25 for two weeks here in calgary and at that temp the engine bay never thaws out.I have water(condensation?)coming up the breather tube and filing up the iac.freezes at night and then won't idle.No amount of driving will thaw it out.you have to take it apart and dry it out.Anyone know why I would get so much water up the breather tube?just had the head gasket replaced two months ago.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_RedTop&174-Starting-Battery-Optima-Batteries_16080024-P_2916_R|GRPBATTAM2_1373081032___#
