35s and new rims
Old Jan 17, 2011 | 10:01 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
To answer the OP's other question, bigger heavier tires like those with 17's will likely weigh more than then stock 20s and 33s. That means more fuel to start, more brake pads to stop usually all around less MPG to a slight degree.
Old Jan 17, 2011 | 11:23 AM
rocket23's Avatar
rocket23
Originally Posted by JDG103
negative....you can not fit a 16" wheel on a 3rd gen Ram, even if u file down the caliper it still wont fit...the smallest you can go is a 17" and it needs to be a front mount wheel if it is a 17"
This was already established, I was refering to a 35'' diameter on a stock 20'' wheel, sorry for the confusion.
Old Jan 18, 2011 | 01:03 AM
ram15008's Avatar
ram15008
sorry should of gave more info its a 08 4.7 i would get the 17inch rim. I was planning on leveling it then getting a body lift, would i lose alot of power by doing that?
Old Jan 18, 2011 | 10:10 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You would not lose A LOT but may notice it might now have as much "umph". Most guys when they go bigger tires/rims they also re-gear the rear end to offset the larger rims/tires
Old Jan 18, 2011 | 11:28 AM
Matt99's Avatar
Matt99
you know, mine doesnt feel any worse but MPG sure thinks its bad. I had to have dropped 5mpg between the level, lift, tires, and new muffler.
I will be regearing
Old Jan 18, 2011 | 02:10 PM
rocket23's Avatar
rocket23
I will be regearing
Your lift was recent? I could of sworn you were sporting just a level, when I leveled mine. (back in may) 2010.
Old Jan 18, 2011 | 04:31 PM
Matt99's Avatar
Matt99
I did a level way back when, Im not sure how long ago. I put a body lift on last summer
Old Jan 18, 2011 | 05:07 PM
outcast's Avatar
outcast
if ur goin to do any mudding i woulnt do it i have the stock 20's and i hate them in the mudd they get off balance bad from the mud the 17's wont do it as bad id go with the 17's. As for tire wieght look at the tires web site for weight most will tell u u can prob get a 17 rim and tire that wieghts less than a 20 and tire combo if u lookcause the tire wieghts dont very that much and im sure the 17's are a lot lighter that the 20's
