Winch Wiring
Old Jan 19, 2011 | 09:53 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I called Jones Welding local to me but im sure all would be the same. The price of copper is the same where ever you go.
Old Jan 19, 2011 | 01:27 PM
HammerZ71's Avatar
HammerZ71
Depends on how much the place wants to make off it. Lowes in my neighborhood has it on big wooden rolls, the ones you see people making into coffee tables and such and are more than happy to spool you off however much you need at the "bargain price" of $4.39 per foot in 2 gauge...
Old Jan 19, 2011 | 02:53 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
ouch.....
Old Jan 21, 2011 | 01:54 PM
1987notchback's Avatar
1987notchback
wow, i was at home depot yesterday thats where i bought the 4 gauge for 98 cents a foot, i looked at the 2 gauge it was about 1.69 a foot.. when i have the cash i will grab it bc the setup I have is a PTA and like hammer said not the best. i am not looking foward to crawling under my truck it is colder than usual even for a new england winter tommorow is a high 12 low of 0! I would use my uncles garage bc it has a little propane heater but my project mustang is in there.... when i get a chance i am going to take a ride to tax free NH only about 15min from me and get the connectors from the welding house i use.
Old Mar 19, 2011 | 06:44 AM
1987notchback
ok so the warm weather is here i am itching to pull some stumps! i am gonna do some maintenece on the truck and while i am under it i am going to run some string and get a general route and measurement of how much wire i will need. here is a dumb question.... when i route the negative cable do i have to run it all the way from the battery to the back of the truck with the positive or can i use a shorter piece for the negative wire and ground it to the frame? thanks mike
Old Mar 19, 2011 | 08:55 AM
HammerZ71's Avatar
HammerZ71
Although it's perfectly fine to ground most things to chassis (frame), it's not a good idea to do so with a winch. True, a battery is already grounded to the frame, which is why you can ground most items to the frame, a stock ground strap from your fender to the battery is almost never stout enough as winches can easily draw 400+ amps If you don't have enough capacity in your grounding cable your winch will not pull it's capacity, in addiiton it will get much hotter, much faster.
Check the ground between the battery and chassis, if it's not as thick as the negative cable for the winch, either replace it with the same 2 gauge you are using for the winch or ground the winch directly to the battery
Old Mar 19, 2011 | 10:42 AM
1987notchback
ok will do thanks for the info mike
