2wd Lift or Leveling Kit
Old Jan 18, 2011 | 03:53 PM
FlChris's Avatar
FlChris
Default 2wd Lift or Leveling Kit
I have 2006 Ram 1500 4.7 v8 2wd and looking for a lift or leveling kit? I would like to put the truck on 33's or bigger and have found different kits but not sure what is the better kit. And don't want to get to crazy on price
1. 02-08 DODGE RAM 1500 2WD 2" Lift Springs Kit (What size tires could run? doesn't say)
2. 05-08 Dodge Ram 1500 4" Lift Spindles
3. 2WD Suspension Lift by Pro Comp- 2006-08
4.2WD Suspension Lift by Fabtech- 2006 Dodge
5.6" Lift 06-08 Dodge Ram 1500 trailmaster
And any others
Thank You
Chris
Old Jan 18, 2011 | 04:04 PM
dirtydog's Avatar
dirtydog
Moderate User
Welcome to the site. I think you need to spend some time doing a little searching as there is tons of info out there cuz that's alot of questions just for possibilities.
Check out the Faq section and THIS link for lift kits and This link for tire info.
Old Jan 18, 2011 | 04:34 PM
Matt99's Avatar
Matt99
yea thats a huge difference in price you are looking at. Over $2,000 and under $100.
Old Jan 18, 2011 | 05:14 PM
oefootball_70's Avatar
oefootball_70
Fo sho, I would do a 2 inch level and 3 inch body lift like Matt is running above me.
I wouldn't drop the coin on the expensive lifts if I had an 06 and up. 05 down have cheap rough country.
Old Jan 18, 2011 | 09:51 PM
FlChris's Avatar
FlChris
K thank you for the input. Are body lift hard to do and do u recommend a body lift kit. And with that what size tire could i run?
Thank You
Old Jan 18, 2011 | 09:54 PM
Matt99's Avatar
Matt99
Its not easy, but doable. I have 35/12.5 r20s on mine.
best body lift for you is the Zone kit. Liftkits4less on ebay has em and I offered $320 and they accepted
Old Jan 18, 2011 | 10:04 PM
FlChris's Avatar
FlChris
Ok thank you Matt, i will look in to it.
Old Jan 18, 2011 | 10:32 PM
Matt99's Avatar
Matt99
Okay just saw that this thread was authored by you. The info in the PM will be right, but if you are looking to do a body lift i would hold off on tires, throw the body lift on, and then buy some 35s. 33s look kinda goofy with a body lift
you specifically asked about the 2in level, and if that is all you are doing then just go ahead with the tires you PMd me about.
Old Jan 19, 2011 | 09:21 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Dont forget lift spindles prices at about 270 on ebay
Old Jan 19, 2011 | 10:30 PM
FlChris's Avatar
FlChris
What about the 4" spindles and the 2" spring with blocks in the rear?
