P0455 Evaporative Emission Control System Leak Detected (gross leak)
Old Jun 18, 2005 | 12:17 AM
sig's Avatar
sig
Default P0455 Evaporative Emission Control System Leak Detected (gross leak)
damn it!!!![:@] P0455 Evaporative Emission Control System Leak Detected (gross leak)
anyone have any suggestions as to where to start?!?!?!i got this with p0442 Evaporative Emission Control System Leak Detected (small leak) i can solve 0442,but dont know anything about 0455.
[sm=helpout.gif]
Old Jun 19, 2005 | 05:22 AM
gamagatsu1's Avatar
gamagatsu1
Default RE: P0455 Evaporative Emission Control System Leak Detected (gross leak)
i H ave been having this problem too i took my truck in on friday so they could "take care of it" by replacing a hose that goes from to the charcoal filter but after the tech tested it, it was still leaking so now i have to take it back in so the can remove the fuel sending unit witch is in hte fuel tank i'll let you know how it goes, part should be in tue. and i assume it should be done with in a day.
I LOVE THE WARRANTY!!!!!
Old Jul 7, 2005 | 11:47 PM
gamagatsu1's Avatar
gamagatsu1
well finally got my truck back for my emissons code dealer had to replace my gas tank and all is well except that it went back in yesterday to have the rearend replaced
Old Jul 15, 2005 | 08:28 PM
tsio's Avatar
tsio
if you can handle an evap leak, you can handle any evap leak...
i do these daily and the most common failures are the gas cap not being on all the way (some people...*shakes head*), the big hose into the canister, or the gas tank lock ring. the smaller failures could be anything but the gross/large leak should be pretty obvious. if it's a newer truck (a few thousand on the odo) I'd look more at blaming the canister or the switch...you can use a vacuum pump to see if they're sealed.
Old Jul 18, 2005 | 04:35 PM
nothingleft's Avatar
nothingleft
Default Depending on your mileage it may be covered...
I had the small leak on my 02 and replaced the gas cap. It did not go away. If you look in the manual the emissions warranty is like 60K or 70K miles. I took my truck to the dealer and they found a bulge in one of the evap hoses. They replaced the hose and the light went out. It was all covered under warranty. I have 36500 miles on my truck.
