Old Aug 5, 2015, 09:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Guides
Print Wikipost
Hemi Oil Change ?
Old Jan 23, 2011 | 05:06 PM
Hemi_2008's Avatar
Hemi_2008
Default Hemi Oil Change ?
Hey all
Just bought a 2008 Dodge Ram 3500 with the 5.7 Hemi. How many quarts of oil? First gas trucck ive had in a while. Had an 04 Hemi 3500 think it was 7 quarts.....correct me if wrong
Thanks!
Mike
Old Jan 23, 2011 | 05:51 PM
Kscha41's Avatar
Kscha41
I'm pretty sure it is still 7 quarts.
Old Jan 23, 2011 | 05:57 PM
Hemi_2008's Avatar
Hemi_2008
Thanks
Old Jan 23, 2011 | 09:12 PM
MikeHTally's Avatar
MikeHTally
Still seven quarts. No O/M?
Old Jan 23, 2011 | 09:27 PM
Hemi_2008's Avatar
Hemi_2008
Im sure there is, but i pick truck up tomorrow. Just figured faster here that way just grab oil/filter on way home. Thanks for reply.
Old Jan 23, 2011 | 09:31 PM
MikeHTally's Avatar
MikeHTally
Ah, that would make a difference. 5W-20, seven quarts. Filter of your choice. I'm partial to K&N.
Old Jan 24, 2011 | 12:36 AM
Hemi_2008's Avatar
Hemi_2008
Cool man thanks! I thought it was 10w 30. or think i use to use that.
Thanks again.
Old Jan 24, 2011 | 06:51 AM
NHHEMI's Avatar
NHHEMI
Yes, it is 7 qts. The factory oil recommendation for your truck is 5W-20 if under 14,000lbs GVWR or 5W-30 if over 14,000lbs GVWR. You don't have MDS so you can run the 5W-30 either way.
Note - the filters for the 08+ HEMI changed. It is not the same one you would have used on your 04. They now use a metric thread. MOPAR MO899 is the number( cross to whatever brand you like ).
Old Jan 24, 2011 | 12:40 PM
Hemi_2008's Avatar
Hemi_2008
Thanks for the reply! very helpful. Cant wait to pick the truck up today.
Old Jan 25, 2011 | 08:04 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Fumoto oil valves work really well also.
