4wd indicator light not workng
Old Aug 25, 2011 | 12:03 AM
John  M's Avatar
John M
Since it doesn't light with the self-check, it may just be the bulb. Simplest fixes first!
Old Aug 26, 2011 | 09:38 PM
Wanderer's Avatar
Wanderer
Bludodge05
FROM THE SERVICE MANUAL, Page 21-443
POSITION SENSOR
DESCRIPTION
The transfer case position sensor is an electronic
device whose output can be interpreted to indicate
the transfer case’s current operating mode. The sensor
consists of a five position, resistive multiplexed
circuit which returns a specific resistance value to
the Powertrain Control Module (PCM) for each transfer
case operating mode. The sensor is located on the
top of the transfer case, just left of the transfer case
centerline and rides against the sector plate roostercomb.
The PCM supplies 5VDC (+/- 0.5V) to the sensor
and monitors the return voltage to determine the
sector plate, and therefore the transfer case, position.
OPERATION
During normal vehicle operation, the Powertrain
Control Module (PCM) monitors the transfer case
position sensor return voltage to determine the operating
mode of the transfer case. Refer to the Operating
Mode Versus Resistance table for the correct
resistance for each position (Fig. 87).
OPERATING MODE VERSUS RESISTANCE
SENSOR POSITION OPERATING MODE SENSOR RESISTANCE (ohms)
1 2H 1124-1243
2 4H 650-719
3 NEUTRAL 389-431
4 4L 199-221
5 NOT USED 57-64
REMOVAL
(1) Raise and support the vehicle.
(2) Disengage the transfer case position sensor
connector from the position sensor.
(3) Remove the position sensor from the transfer
case.
INSTALLATION
(1) Inspect the o-ring seal on the transfer case
position sensor. Replace the o-ring if necessary.
(2) Install the transfer case position sensor into
the transfer case. Torque the sensor to 20-34 N·m
(15-25 ft.lbs.).
(3) Engage the transfer case position sensor connector
to the position sensor.
(4) Lower vehicle.
(5) Verify proper sensor operation.
Fig. 87 Position Sensor Linear Movement
1 - POSITION 1 - 10mm ±0.5mm
2 - POSITION 2 - 12mm ±0.5mm
3 - POSITION 3 - 14mm ±0.5mm
4 - POSITION 4 - 16mm ±0.5mm
5 - POSITION 5 - 18mm ±0.5mm
6 - POSITION 6 - 20mm±0.5mm - FULL EXTENSION
Old Aug 26, 2011 | 09:41 PM
Wanderer's Avatar
Wanderer
John M
There is no bulb, it part of the board in the dash, big bucks. Dealer told me the sensor is a common replacement part.
Old Aug 27, 2011 | 12:38 AM
John  M's Avatar
John M
The warning lights in our cluster are LEDs on the circuit board? I haven't heard that before.
