Electrical Help
Old Feb 1, 2011 | 09:30 PM
  #21
HouseApe's Avatar
HouseApe
Originally Posted by Travelin man
HouseApe I like your idea but I'm a little confussed you said to connect 87a to the hot side of the leds meaning the + ...
Correct
...and 30 to the battery through a fuse...
Correct
...to the hot side of the leds......
Incorrect. Power will come from the Battery (through a fuse) to 30 then flow out 87a to your LED's + side. You will just need to run the LED ground to a good ground.
...how can you connect both hot sides of the leds to 87a and 30 ? ...
We are not see above.
...where do you connect the - of the leds ? can I just grond it to the frame .
Yes or any good ground.
I edited my first post, as I had copy and pasted and screwd it up so I confused you...sorry
Old Feb 2, 2011 | 08:44 AM
  #22
Travelin man's Avatar
Travelin man
HouseApe thanks for the help I new there was a way to do this . Do you know were I can get this relay is it just a regular relay from a auto parts store ?
Old Feb 2, 2011 | 09:48 AM
  #23
HouseApe's Avatar
HouseApe
Yes just a regular relay with 5 terminals. You should be able to get it anywhere.
Old Feb 2, 2011 | 05:22 PM
  #24
Travelin man
I stop at the auto parts store and pick one up but I'm going to have to wait until next weekend to try it I have to work out of town this weekend .I let you know how it turns out thanks again for the help.
Old Feb 6, 2011 | 09:02 PM
  #25
Travelin man
HouseApe I got the leds installed today . It took a little bit but it worked like a charm
Old Feb 6, 2011 | 10:56 PM
  #26
HouseApe's Avatar
HouseApe
Glad I could help.
