Ok quick question!
Yep, chalk mark the tires and drive shaft and found how many times to drive shaft spins in relation to the tire.
What size rims cam with your truck stock? If it was 17s then you likely have 355s. If it came with 20s then you likely have 392s.
You can also request a built sheet on the truck to tell you everything that came with it.
