Whats up
Old Feb 1, 2011 | 08:51 PM
p38251's Avatar
p38251
Default Whats up
John for Spoakne Wa. 2004 1500 5.7 285/70/17 tires I see some discussions on gearing. I have the same problem. Truck came with 3.55. Towing 7000lb trailer. My local gear shop has recommended 4.56. The rpm range he said the truck will run seems high to me. I thought 4.10 should be good. But I could be wrong. Anyone have either setup. Looking for recommendations and feed back
Thanks FallGuy
Old Feb 2, 2011 | 08:07 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the third generation Ram section,
FF
Old Feb 2, 2011 | 08:26 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
With 325/45/24 tires (36") I run at about 2000 rpm at 70 mph.
Welcome to the site BTW.
But for 275/70/17 (32") I would do 410s also (unless you ever plan on getting bigger tires later)
Old Feb 2, 2011 | 10:09 PM
03MopaRamman's Avatar
03MopaRamman
4.56's with 285 Tires she revs as you see doing 77 MPH US.
Can't find the other photo but at 2200 (Sweet Spot I believe I'm Running 65-70).
For the Money I'd recommend the 456's as these Trucks can only run so fast for so long anyhow and if towing is your thing and you don't own a Diesel this is the Gear Ratio to have IMO.
