Stumble/Hesitation
Old Feb 5, 2011 | 12:38 AM
fatty270's Avatar
fatty270
Default Stumble/Hesitation
I have an 05 Ram Hemi and have been experiencing stumbling and hesitation shortly after starting up and driving when the truck is cold. Today it actually popped like a backfire, this is a first.
Recently I have done some tune up work (Plugs/Wires) (Throttle Plate Cleaned) to try and maybe solve the issue.
I am getting no CEL or codes so I have no leads as to what may be the problem.
From reading other threads the EGR valve may be the culprit but those threads seemed to always say that there was a CEL or code associated with a EGR problem.
Any other ideas????
Old Feb 5, 2011 | 03:04 AM
Marx's Avatar
Marx
try resetting the computer (PCM) by disconnecting the battery and waiting 20 mins then reconnect. Theres a quicker way but i can't remember and i don't want to give bad info lol
These trucks like to be reset if a part is replaced (air filter), or you clean it (TB)
Old Feb 5, 2011 | 09:53 AM
fatty270's Avatar
fatty270
I have already done that as well, meant to add that before. Thanks for reply though.
Old Feb 5, 2011 | 09:55 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Have you checked all the vacuum lines also for leaks
Old Feb 5, 2011 | 12:38 PM
jeman022004's Avatar
jeman022004
I have an 05 as well and had similar issues (no backfire). My truck ran like that for a few weeks before the EGR valve CEL finally came on. It even stalled on me a few times. That may be the issue....
Old Feb 5, 2011 | 08:45 PM
fatty270's Avatar
fatty270
Ok....I will do a complete vacuum line check, not a bad idea to really know their condition anyways.
Now that you mention it I remember it stalling once.
As well I think I will change out the EGR, why not???.
Thanks
Old Feb 6, 2011 | 01:34 AM
lxman1's Avatar
lxman1
Site Moderator
You can remove it and see if it looks like it is carboned up bad. If so, it is probably sticking open a little bit and causing a lean condition.
Old Feb 6, 2011 | 02:07 AM
fatty270's Avatar
fatty270
My throttle plate was very bad for carbon and crap.....so maybe it is sticking like you say.
Old Mar 25, 2011 | 12:44 AM
eveey's Avatar
eveey
I had the same issue with my '04 5.7 Hemi, but would do it more below 50F.
I replaced the EGR valve ($40 O'Rielly's) You have to do a computer reboot or will continue acting up.
1. Remove #23 fuse (PCM)
2. Turn key to on (Not Start)
3. Wait for lights to go out
4. Turn key to Start and hold until 2 beeps. (about 10sec)
5. Reinstall fuse and start, 1st time it wont respond, 2nd time will start.
Hope this helps those that searched forever like i did
Old Mar 25, 2011 | 06:27 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Next time check the stickies posted at the top of the section.
