gas gauge
Old Feb 7, 2011 | 09:16 PM
brantrockink's Avatar
brantrockink
Default gas gauge
Gas gauge works and then doesn't.Any ideas?
Old Feb 9, 2011 | 01:09 AM
05 RAM 2500's Avatar
05 RAM 2500
your sending unit maybe going bad it happened to my buddie in his ford
Old Feb 9, 2011 | 07:49 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
And it could be something as simple as a bad or loose connection somewhere. What year is the truck? Ive got a good and complete fuel pump out in the shop.
Old Feb 9, 2011 | 03:40 PM
brantrockink
2005 2500 it screwed up one day a few times and has not done it since. I'm sure it will again but should wait til fuel pump goes totally at the cost to replace. It's all one unit i think. Drop tank ect. to get at it right?
Old Feb 10, 2011 | 08:25 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, drop the tank, disconnect the fuel lines, disconnect the 4 pin electrical harness, pop off the locking ring on top and lift the pump straight up and out. Not hard at all. Again, Ive got a spare pump if you ever device you need one.
I would let it go for $75 shipped. Ive priced them new at $225
Old Feb 10, 2011 | 01:47 PM
Matthew02Hopkins's Avatar
Matthew02Hopkins
mine does the same thing i can turn on the truck and it will read E then if i turn it off then back on it works fine only happens every now and then
Old Feb 11, 2011 | 11:14 PM
Texans's Avatar
Texans
My 02 does this as well, usually when I'm around half a tank. My mechanic friend says sending unit, but I consider it kind-of harmless, haven't bothered with trying to fix as yet.
