Last edit by: IB Advertising
Browse all: Exterior Guides
- Dodge Ram 2002-2008: How to Remove Rear Bumper
Step by step instructions for the do-it-yourself repairs
2004 1500 rear bumper removal question
I need to replace my rear bumper. I see on the net some pictures/direction to remove 8 bolts. 3 on each end and 2 behind the license plate.
I have a trailer hitch factory and looks like the 2 large bolts go through the bumper. On my bumper there is a plastic step and looks like 2 caps to get to the top of the 2 large bolts. I tried to get the caps off and they are all one piece. How do you get to the top of these 2 bolts so I can get a socket on the bottom and remove them?
thanks
thanks
This might help.
http://ww2.justanswer.com/uploads/Mo...706_bumper.pdf
I changed out my rear bumper about a year and a half ago, it was all straight forward R&R, I don't really know what you are describing.
Let me try again
When I looked under the bumper there were 2 large bolts that looked like the bumper was bolted to the trailer hitch. On the step part of the bumper there are on the plastic step 2 round looking caps. I thought the bolts on the bumper to the hitch are under the caps. I tried to pop up the caps but all one piece. Are the head to the large bolts under the plastic? I don't know if the hitch is bolted to the bumper. It"s a factory hitch.
thanks for the pictures it will help.
By the pictures it does not look like the hitch is bolted to the bumper.
thanks
thanks
No the hitch is not bolted to the bumper, I think it's only 8 bolts all together, the bolts behind the Lic. plate and two on each corner. I have a great memory, it's just short.
I think those caps only cover the holes you would use for safety chains if you were towing a trailer. If I remember correctly, you can remove that whole tread by just pinching the little locking studs together from under the bumper.
