Truck randomly shuts off.
Old Feb 11, 2011 | 12:59 PM
hdoggie24's Avatar
hdoggie24
Default Truck randomly shuts off.
I have a 2006 Ram Hemi and just wanted to know everyones 2 cents on what you think my problem is with my truck.
A few times in 9 months my truck has died driving down the road. Check gauges pop up and beeps at me and truck randomly shuts off.
After a good 1-2 minutes of it turned off, it will fire right up with no problem.
Anyone got any ideas of what is wrong?
Thank.
Old Feb 11, 2011 | 01:32 PM
HouseApe's Avatar
HouseApe
ignition switch ?
Old Feb 11, 2011 | 03:22 PM
Willy McNasty's Avatar
Willy McNasty
Mine did the same thing. You need a new EGR sensor
Old Feb 11, 2011 | 07:04 PM
dirtydog's Avatar
dirtydog
Moderate User
Maybe THIS will help you out?
Old Feb 11, 2011 | 08:21 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
All good things being said. Also check for bad connections at the PDC.
Old Feb 12, 2011 | 10:54 AM
jeman022004's Avatar
jeman022004
My 05 Hemi did that for about two weeks before the EGR valve CEL light finally came on. It would stall on me when letting off the gas while approaching a turn or red light. It was pretty scary trying to turn with no power steering or acceleration...
I saw in some other threads that an updated code version is available for the computer that the dealer can supply. It is "supposed" to resolve the problems. I found this same thing is being experienced in Durango threads as well. It looks like it is common across certain years of HEMI engines. Mine has been running fine since, but if it happens again I am throwing in the towel and getting rid of it.
Old Mar 6, 2011 | 01:10 AM
cjflyrod25's Avatar
cjflyrod25
Default '05 Ram 1500 5.7 Hemi stalls
Have been experiencing stalls when cold in the Ram 109K miles, have had the ERG codes (P404), then EGR replaced 2 yrs ago; have had the P420 code since late fall, have sreset 3X & comes back within a week. The stalls have been present in last 6 months, usually when cold (first 5 minutes or so), usually restarts. No O2 sensors replaced yet, but bank 1 upstream is a start....anything else ??
