Heater Blower
Got into my truck after it was running for 15 min and it felt a little cold. Went to turn up the blower control and notice it only works on High. WTH???
Options? How can I trouble shoot this? Could it have thrown a code? I have tried cycling the ignition key but no luck, maybe I will try O'Rileys?
Any ideas would be helpful, it's a little cool in WI.
Thanks
After doing a little research on the forum, I see it maybe caused by the resistor. Where is that located? Passenger side? Go from the bottom of the dash?
It makes sense.
Thanks
Thanks
It makes sense.
Thanks
mine actually just did this, i had a cluster of wires under my glovebox that the insulation had worn away and was shorting out so i taped them up and it works fine, mine would blow on high only and even then would only be partially warm, its like 6 wires above the floorboard under the glovebox
Yeah, the blower motor resistor. I just replaced mine, roughly $50 at local auto parts store. Cheaper online, but I'm an instant gratification type of guy.
Held in by 2 phillips head screws, is the thing w/ the plug going into it under the dash below the glove box.
Udpate. it was the resistor. Removed it and noticed a little brass piece was broken. I resoldered it and going to try reinstalling it today. Hopefully it works and then it will save me 50bucks.
