How do I install tire chains on a 1500
Old Nov 11, 2008 | 04:38 PM
Billy Goat's Avatar
Billy Goat
Default How do I install tire chains on a 1500
How do Install tire chains on the front tires on my new 2008 1500????
The clearence between the tire and the supprt bar is only about 1/2 to 3/4 inch (behind the tire).
Can't belive I bought a truck I can't even put chains on for winter!
The 2500 and 3500 trucks would be ok (they don't have the clearence problem)
I'm sure some one has an answer to this.
Is there a different rim I can buy?
Why would Dodge do something like this???
Crying out for help, Billy Goat
Old Mar 24, 2009 | 02:27 PM
Billy Goat's Avatar
Billy Goat
Default Tire Chains for 1500
How do I install tire chains on the front of a 1500 dodge truck?
The support arm on the back of the tire is about1/2-3/4" away from the tire and chains would not clear.
Is there a different rim or spacer?
Some one must have an answer. 2500 don't have this clearence problem.
Thanks Billy
Old Mar 24, 2009 | 08:34 PM
Heavy_Sack's Avatar
Heavy_Sack
i may be wrong but i belive the owners manual says do not install chaines on the 1500
Old Mar 24, 2009 | 11:01 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Why put them on the front? You shouldn't be going fast enough to where you'll need them to turn.
Old Mar 25, 2009 | 12:55 AM
04-fourseven's Avatar
04-fourseven
I hate chains... also refuse to use.
Old Mar 25, 2009 | 05:44 PM
mattyk6's Avatar
mattyk6
I've put chains on the front of every 4x4 that I've taken up hunting. I haven't even looked at putting chains on my new truck yet. Having chains on the front with the extra weight, helps with traction.
Old Feb 14, 2011 | 06:38 PM
chrisinWY's Avatar
chrisinWY
I have the same problem. Excuse my rant but dodge needs to hear it because of the stupid design. They market the truck as a rugged work truck but you can't use tire chains on the front. Come on!! I guess not many people go off pavement any more. I also love the suggestion on other forums about only using them on the back or wondering why you would need them on all 4 tires. These people have obviously never been off the black to either. I have on numerous occasions needed chains on all 4 tire and would have put on on the steering wheel if i thought it would have helped. I have used a very thin set of chains of the front end of my 2008 1500 but these chains do not have the grip needed and it is very disappointing I have to use them. If you come up with a solution please let me know. Otherwise I guess my next truck will be a ford.
Old Feb 14, 2011 | 08:37 PM
SeanW727's Avatar
SeanW727
Studded Tires for the winter only.....? Get yourself a backup pair of rims and tires you can run on the front for the winter only.... That would be my suggestion i guess.
Old Feb 15, 2011 | 12:04 PM
mleach82's Avatar
mleach82
Possibly install wheel spacers to give you a bit more clearance?
Old Feb 15, 2011 | 12:10 PM
chrisinWY's Avatar
chrisinWY
A wheel spacer? Tell me more? excuse my ignorance but i am assuming from the name it moves the rim further from the body?
