front outer tie rod problem?
Old Feb 19, 2011 | 12:51 AM
badnews's Avatar
badnews
Default front outer tie rod problem?
whats the measurement for the maximum ware on a outer tie rod on a 2004 dodge ram 1500 4x4? the driver side one is clicking when ever you turn the wheel. should i just go ahead and get a new tie rod end?
thanks.
Old Feb 19, 2011 | 01:14 AM
hyperjay's Avatar
hyperjay
If you can afford to.......just replace both outters with a set of MOOG Greasables. If you're doing one, you might as well do both cause you will need an alignment anyway.
Old Feb 21, 2011 | 10:01 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Find some new Moog tie rods on ebay for cheap and replace them. Be sure to get an alignment after swapping them out. Its not hard. Also check the ball joint boots for cracks or excessive play.
