Rear end noise
Old Feb 21, 2011 | 07:25 PM
DRT's Avatar
DRT
Default Rear end noise
Rear end just started making a grinding noise at low speed. Have 45,000 miles on "06". Any ideas?????????
Old Feb 21, 2011 | 07:41 PM
Cthulhu's Avatar
Cthulhu
Did you check your fluid level?
Old Feb 21, 2011 | 11:53 PM
HammerZ71's Avatar
HammerZ71
Do a search on here for "C-Clips"...
Old Feb 22, 2011 | 09:44 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
All great info. I would say get out there and check the oil level but thats preventive maintenance type stuff. If you are hearing noises then you are past PM type work and now in repair mode. Go pull the cover, drain the oil, clean it all out and inspect everything carefully including the clutch pack retaining clips (C clips) that hammer spoke about.
