02 4.7L wet motor problem
Old Feb 24, 2011 | 07:12 PM
backcountryboy2005's Avatar
backcountryboy2005
Question 02 4.7L wet motor problem
When i hit a water hole seems to be on the passenger side the motor bogs out and run really rough. If i let off the gas and back on it a few time it clears up. I can drine in the rain just fine one when i hit a water hole kind of hard. This just started a few weeks ago. 88k auto trans manual 4X4 shift and no mods. Any help would be great! (before i'm sitting along the road).
Old Feb 25, 2011 | 08:16 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
So obviously something is getting wet. maybe you should check all your electrical connections and try to waterproof them??
Old Feb 25, 2011 | 01:57 PM
4.7Ram5.7Rango's Avatar
4.7Ram5.7Rango
Passenger side = air filter.... getting water in your intake is no bueno....
Old Feb 25, 2011 | 03:49 PM
backcountryboy2005
The motor dosent act like it's not getting air and for the electrical it clears up in just a minute or 2 after I hit the water hole. The truck makes like a humming sound loses power and u can feel the humming through the whole truck. I've blasted water holes before no problems. Just of lately it's been dying this.
Old Feb 25, 2011 | 03:50 PM
backcountryboy2005
The motor dosent act like it's not getting air and for the electrical it clears up in just a minute or 2 after I hit the water hole. The truck makes like a humming sound loses power and u can feel the humming through the whole truck. I've blasted water holes before no problems. Just of lately it's been doing this.
Old Feb 26, 2011 | 09:27 PM
04sltram's Avatar
04sltram
just sounds like your sucking up water, it will cause it to have a miss and loss of power for a min. but thats just my thoughts
Old Feb 26, 2011 | 09:36 PM
That1guy's Avatar
That1guy
Is your wheel liner intact and good? Next time it happens pull over and see whats wet. Both the computer and airbox is on that side.
Old Feb 28, 2011 | 03:09 PM
backcountryboy2005
Thanks for the input I'll try to get stopped and check those 2 locations and let you know.
