2003 ram 1500 bad milage
Old 02-24-2011, 10:30 PM
miller76's Avatar
miller76
miller76 is offline
Default 2003 ram 1500 bad milage
my check engine light is on and i have changed the down stream o2 sensor?
Old 02-24-2011, 10:46 PM
vinnierap's Avatar
vinnierap
vinnierap is offline
did you check what codes you are throwing? Truck off, hold down the trip meter and then turn the truck to acc. There will be a code displayed at the bottom where the mileage is displayed. Might be easier to help diagnose the problem.
Old 02-25-2011, 08:09 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Do yourself a better favor and take the truck to a local auto parts store and tell them the CEL is on. Let them connect their ODBII scanner to the truck and tell you what codes are on. Then bring them back here and post them so we can help you out.
Doing the procedure listed above will work but will not give all the DTC codes that might be logged.
Old 02-25-2011, 11:26 AM
dodgeboy1979's Avatar
dodgeboy1979
dodgeboy1979 is offline
If you have poor gas mileage changing the downstream sensor won't do anything. The upstream sensor is what tells the PCM weather your truck is running rich, lean etc. Like stated above get the codes read, but i would guarantee your problem is the upstream sensor and maybe a plugged CAT.
Old 02-26-2011, 12:11 PM
miller76's Avatar
miller76
miller76 is offline
Code hr3532
Old 03-08-2011, 12:45 PM
miller76's Avatar
miller76
miller76 is offline
chat is code 3555?
Old 03-08-2011, 01:04 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
hr3532 is how man hours the truck has logged.
Go back and re-read post 3 please
Old 03-09-2011, 01:22 PM
miller76's Avatar
miller76
miller76 is offline
p0420 is the code
Old 03-09-2011, 01:48 PM
tstar51's Avatar
tstar51
tstar51 is offline
P0420 Catalyst Efficiency Below Threshold (Bank 1)
Old 03-09-2011, 01:53 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
That could be a bad front O2, a bad cat or a leak somewhere in front of the O2 and cat. Check the exhaust manifold bolts on that side and make sure none are broken or loose
Quick Reply: 2003 ram 1500 bad milage
