2008 2wd leveling kit pictures please!
Old Feb 27, 2011 | 09:15 PM
Biscuit027's Avatar
Biscuit027
Default 2008 2wd leveling kit pictures please!
Ok, i already have the 2 inch daystar leveling kit but that does not level it out all the way, does anyone have the 2.5 inch leveling kit, if so i would like to see some pictures. thank you!
Old Feb 27, 2011 | 09:43 PM
Matt99's Avatar
Matt99
you dont want a 2.5in spacer. Trade the spacer in on a set of spindles. My UCA hits the spring bucket all the time. But heres a 2.5in spacer and 1in block in the back
Old Feb 28, 2011 | 07:10 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
just curious on what you expect to see in the differences between a 2" level and a 2.5" level because at a normal distance of a few feet (or more) in a picture you will not see 0.5" difference.
However, go out and measure the height from the ground to the top of the fender well lip in the front and back and see what the difference is. Then you will know what has to be lowered or taken higher.
