O2 Sensor replacement
Old Mar 1, 2011 | 02:21 PM
gordie580's Avatar
gordie580
Default O2 Sensor replacement
I need to change out my O2 Sensor behind the cat both of them. Has anyone done this is it hard or easy? I do not have a lift and is it possible to change it without the lift.
take a picture
thanks
Old Mar 1, 2011 | 03:06 PM
ElHombre03's Avatar
ElHombre03
Default O2 Sensors
Gordie,
Not so tough. I changed out the originals on an 03 4x4 in 2010. Just soak the threads with some type of thin lubricant for a day if you can. Use a suitable O2 socket and remove and install. You don't need a lift if it is 4 wheel drive, but might help to put up on jack stands.
Old Mar 1, 2011 | 05:04 PM
JDG103's Avatar
JDG103
yea it shouldnt be that hard at all...use some WD40, and remember to disconnect your battery before doin all of this
Old Mar 1, 2011 | 05:39 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
3/4 wrench works also. Just disconnect them, unscrew them and replace them. Not hard at all.
Old Mar 2, 2011 | 09:10 AM
Freybird's Avatar
Freybird
I did this last week. The sensor after the cat was a breeze, the sensor before the cat was a bear; both were soaked with PB blaster. I did not have an 02 sensor socket as was recommended above. I suspect this would have made the job easier as there was little room to turn a wrench.
