Replacing a broken radio
Old Mar 3, 2011 | 01:36 PM
g_svan's Avatar
g_svan
Default Replacing a broken radio
Hi!
I'm about to replace a broken radio/cd charger in my 2004 Dodge RAM 1500.
To make the switch, do I need to remove the center console, or just the center trim?
Anyone have a DIY?
Thanks,
g_svan
Old Mar 3, 2011 | 02:57 PM
AJOSSY's Avatar
AJOSSY
Default Radio Replacment
I recently replaced my factory radio with an aftermarket one.
I ordered two kits from Crutchfield:
Item Description Amount
120706502 Chrysler/Dodge Wire Harness receiver, 2001-up 14.99
120996503 Chrysler Concorde/Dodge LHS 1998-up, 14.99
0000160097 DODG PKUP 02- (FULL SIZE) MS 0.00
Made installation a breeze took about 5 minutes, best thing is I can go back to factory in the same amount of time if desired.
The kit comes with instructions on how to remove the dash panel.
Step 1 is to remove the screw right about the trash bag hook on the right hand side of the center console.
Then carefully pull the entire center console out, not just the portion around the radio and climate controls. There are 10 clips that hold the cover in place.
Hope this helps.. I can scan and post the diagram this evening if needed.
Old Mar 3, 2011 | 03:03 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Remove the screw behind the hook by the glovebox and pull the console facing off. There are four screws that hold the radio in place.
What radio are you going to go with? I make the bezels for the double DINs if you are looking for one.
Old Mar 3, 2011 | 03:14 PM
SHNOOL's Avatar
SHNOOL
+1 screw behind the bag hook.. Pop center console out.
I went to Walmart picked up the scosche adapter kit for RAM/Durango '01-06 or something, was like half the price of Crutchfield's... Am I the only one whose back speaker wires got toasted? I have to run new wires to the rear speakers (someday)...
However, if you buy all the stuff from Crutchfield, they give you detailed instructions on how to do the change, included with the proper wiring harness adapter etc.
Old Mar 3, 2011 | 03:27 PM
AJOSSY's Avatar
AJOSSY
somehow I got a double post... sorry.
Old Mar 3, 2011 | 05:56 PM
Matt99's Avatar
Matt99
there is a guy on DT that is selling two factory cd units for like $50/each. good deal IMO
Old Mar 4, 2011 | 01:02 AM
chefred112's Avatar
chefred112
hmm, I didn't unscrew anything until I popped the trim off surrounding the radio...then just a couple screws holding radio in..
Old Mar 4, 2011 | 06:34 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Fred, now you know your aint no spring chicken anymore.
You sure you dont remember taking out that phillips head screw from behind the hook? LOL
Old Mar 4, 2011 | 06:35 AM
g_svan's Avatar
g_svan
Thumbs up Thanks!!!
Thanks for all the help - install will now be a breeze
/g_svan
Old Mar 4, 2011 | 08:42 AM
chefred112's Avatar
chefred112
hehe, I bet your right Mikee...couldn't figure out why i had extra screws years ago..lol
