towing camper
Old Mar 17, 2011 | 09:34 PM
900cfi's Avatar
900cfi
Default towing camper
I have a 2007 quad cab 4x4 with a GVWR of 6700lbs.How heavy of a camper can I haul as I can't figure this out?
Old Mar 17, 2011 | 10:14 PM
MikeHTally's Avatar
MikeHTally
Dodge's website can provide some info, but I'd guess somewhere around 7,200 lbs. GVWR isn't what you want to use. Rather, use GCWR. That's probably about 14,000 lbs (truck, trailer, contents, people - everything).
Bent's Avatar
Bent
'bout 1200 pounds - without any occupants or cargo in the cab.
Old Mar 17, 2011 | 10:15 PM
Bent's Avatar
Bent
hehehe I think he meant slide-in camper, not pull behind.
Old Mar 17, 2011 | 10:21 PM
900cfi's Avatar
900cfi
Pull behind camper is what I am refering to.
Old Mar 17, 2011 | 10:43 PM
wishywashy's Avatar
wishywashy
Take a look at this:
http://www.dodge.com/towing/D/vehicl...2BTransmission
I have the same basic truck and pull a 6500lbs (with water/propane...) camp trailer without any issues. I have an equalizer hitch and electric brakes to go along with it.
Old Mar 17, 2011 | 10:47 PM
gcburkett's Avatar
gcburkett
I am think the payload capacity is only 1300lb on the quad cab 4x4. You would really need to know the weight of your truck. Subtract the weight that would be in the truck. The remaining payload can be used for for the tongue weight of the trailer. Multiple this by 8 and this close to your max trailer weight. This assumes 12.5% tongue weight. So if you have 600 lbs of passengers in the truck then (1300-600) * 8 = 5600lb. I am assuming you have the 5.7 HEMI. Does not matter much which gears. If you were pulling a light tongue boat then gearing would matter more.
