rear axle help
Old Mar 17, 2011 | 09:59 PM
outcast's Avatar
outcast
Default rear axle help
So my rear axle decided to blow up on me this past weekend. I need everything but the axles. Im going cheap for now where could i find cheap gears(all),LSD clutches. And how hard would it be to put back toghter. Me and my dad both know wat we are doin when it comes to cars but we know nothin about settin up rear axle gears. So is it pretty easy or just go and take it to a shop. Im puttin the stock size gears back in it for now. Thanks for any help.
Old Mar 17, 2011 | 10:18 PM
T-Muns's Avatar
T-Muns
A lot of guys on here end up getting a shop to do it, although there is a good gear install thread if you search. I think the typical rate is ~$250 labor per axle. From what I've read, it is pretty difficult and if you don't do it right, you can damage the new ring & pinion. Sounds like a good time to upgrade?
I just got done doing an engine swap and I didn't want to attempt the gear install. My truck is in the shop right now getting 4.56s.
I would look on ebay and craigslist for gears. I found mine cheap on craigslist and a 4x4 forum that I stumbled upon using google.
Old Mar 18, 2011 | 08:33 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I could probably have done mine being as mechanical inclined as I am but at the cost of the special tools I would have needed versus how many times in the future I would have used them, I just paid a guy 250 to do mine and be done with it. Sorry i cant help more
Old Mar 19, 2011 | 12:04 PM
outcast's Avatar
outcast
So i was thinkin if i have to do my rear gears y not just save up and change my front ones. I have 392's in it now a little to high but i hear a lot of guys goin to 456's. I think that would be to low anything between a 410 and 456 for front and rear? I do alot of muddin so wat would be a good locker and do they make any kind of posi or lockers for the front end.
Old Mar 19, 2011 | 01:53 PM
draco8494's Avatar
draco8494
u need a selectable for the front either eaton or ARB..you can get a detroit also...but if i were you if its just the rear ide look for one at a junkyard..whole axle will prolly be about 250 bucks...vs just the ring and pinion being that much...my .02
