2010 17's fit on 2004 1500?
Old 03-18-2011 | 11:53 AM
Go_Green's Avatar
Go_Green
Default 2010 17's fit on 2004 1500?
Will a set of 17" wheels from a 2010 1500 fit on a 2004 1500 4x4? I'm sure the bolt pattern is the same, but what about the hub centers or provisions for sensor on the 2010's?
Old 03-18-2011 | 12:05 PM
dirtydog's Avatar
dirtydog
Moderate User
I believe all the 09+ wheels have more of a positive offset than the 08-prior wheels. This means that the wheel goes further into the fender which could cause caliper clearance issue's, wheel rub..etc
But, the difference is negligible so I doubt there would be issue's, so YES you can fit both 17" and 20" wheels from the newer trucks to our older one's.
Old 03-18-2011 | 12:14 PM
Go_Green's Avatar
Go_Green
Hmmmmm...I'd eventually be putting 33's or 35's on them so with the pos offset I would likely run into rubbing issues?
Quick Reply: 2010 17's fit on 2004 1500?
