broken evap line connector on tank
Old Mar 27, 2011 | 01:17 PM
kemo98's Avatar
kemo98
Default broken evap line connector on tank
I was changing my fuel pump and happened to break off the evap line connector that is on the tank. im not sure if the cap that the evap lines all connect to is replaceable or if it fixed into the tank and the tank is junk. any suggestions? i have the lines blocked off on the filler neck and the evap connector but now it fills very slowly due to the breather on the neck blocked. thank you
