quick wheel backspacing question
Old Mar 27, 2011 | 02:57 PM
e36m3e's Avatar
e36m3e
Default quick wheel backspacing question
4x4 megacab CTD. no lift and no lift in future.
going from 17" to 18" wheels just because. I have available to choose from 4.5 and 5.7 back spacing. it's my understanding from reading around here that the 4.5 is for lift kits that have parts that need more clearance...and the 5.7 is more for a stock fender alignment look, which is what I'm after. I don't want the wheels to stick out.
I'm probably going to put 295/70x18 Terra Graps on these and from what I have read they will fit with stock style alignments.
any info would be greatly appreciated. Thanks.
-E
Old Mar 27, 2011 | 03:19 PM
HammerZ71's Avatar
HammerZ71
You are correct, less backspacing means wider stance or basically the wheels stick out farther. So in your case, where you want them tucked under wheel well, you would go for the greater backspacing. Also, be aware that offset plays a part in this as well. A negative backspace widens the stance whereas a positive one keeps it narrower...
Old Mar 27, 2011 | 03:36 PM
e36m3e's Avatar
e36m3e
thanks for your quick response and I get what you're saying but aren't we using two different ways of measuring to indicate the same thing? for instance the wheels I am looking at offer -12mm offset 4.5" backspacing or +18mm offset 5.7" back spacing. if you consider the total difference in offset of 30mm (1.2") and apply that to either of backspacing #s positively or negatively you get the other back spacing #. 4.5" + 1.2" = 5.7"
seems to me that yes offset is a factor but in the same quantitative dimension as back spacing in this particular instance. to me if you measure backspacing it is what it is.
-E
Old Mar 27, 2011 | 03:56 PM
HammerZ71's Avatar
HammerZ71
In your example yes. I was basically referring to if you had wheels with the identical backspacing, offset would play into how far they stuck out of stayed under the wheel well.
I've seen wheels with the identical backspacing offered in a negative, positive and no offset versions.
Old Mar 27, 2011 | 09:14 PM
olyelr's Avatar
olyelr
Just to clear things up, backspacing is simply the distance from the wheel mounting surface to the inner edge of the wheel. Offset is the distance the wheel mounting surface is from the center of the wheel, which can be a positive number or negative depending which side it is on.
As long as your new wheel is the same width and backspacing as your stock ones then it will sit in the wheel well the same.
olyelr's Avatar
olyelr
The only way that is possible is if the wheels were different widths.
Old Mar 27, 2011 | 09:17 PM
olyelr's Avatar
olyelr
How to Measure Wheel BackSpace
Items required to measure wheel backspace: Tape measureStraight edgeWheel w/o tire (preferred)The easiest way to measure backspace is to lay the wheel face down onto the ground so the backside of the wheel is facing up. Take a straight edge and lay it diagonally across the inboard flange of the wheel. Take a tape measure and measure the distance from where the straight edge contacts the inboard flange to the hub mounting pad of the wheel. This measurement is backspace. The above photo shows three wheels with 2",3", & 4" backspace.
Measuring Wheel Offset
To calculate offset you'll need the following measurements:
Wheel backspaceWheel WidthWheel Center line (outboard flange to inboard flange measurement / 2)Subtract:
Wheel center line from Wheel backspace to get offset. If backspace is less than the wheel centerline the offset is negativeIf backspace is greater than the wheel centerline the offset is positiveTip:
To convert from inches to mm multiply by 25.4To convert from mm to inches divide by 25.4
Old Mar 28, 2011 | 05:05 AM
e36m3e's Avatar
e36m3e
Thanks for the info guys. This is all confirming what I have read and learned.
Does anyone happen to know what the stock offset or backspacing is on the 17" plastic chrome steel wheels? Otherwise I'll pull one and measure it.
Thanks again.
-E
Old Mar 28, 2011 | 06:19 AM
olyelr's Avatar
olyelr
Thanks again.
-E
Not off hand, but there is a set I can measure over at my old mans. I will check today while at work. I am pretty sure they are 8" wide and somewhere around 5.5" of backspacing.
Old Mar 28, 2011 | 01:58 PM
e36m3e's Avatar
e36m3e
yeah that's prob right from what I have been reading...be lot easier for me to jerk one and measure than for you to go somewhere. thanks for the offer though.
-E
