front end unlevel????
i have a 2006 dodge ram 1500 with a 2 and a half inch leveling kit on it its always sat perfectly level until i put new cv shafts tie rod ends and upper a arm with the ball joint in it, i only replaced the upper a arm on one side, cause the other side is fine but when i got home and looked at it my truck is sitting about an inch higher on the side that has the new a arm, i already jacked the other side up and loosened the bolts on the a arm then tightened them back up, its still unlevel... whats going on???
