Factory fog light taking on water
Old Mar 28, 2011 | 06:30 PM
Bent's Avatar
Bent
Default Factory fog light taking on water
My OEM Hella on the passenger side had i/2" of water in it today.
I removed the assy, cleaned and dried it, and re-installed it.
What is more likely, the seal between the lens and reflector, or the bulb/o-ring?
Old Mar 28, 2011 | 06:52 PM
Geezir's Avatar
Geezir
I'd say run a bead of silicone around the lens and assembly
Old Mar 29, 2011 | 08:59 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Thats a considerable amount of water. How did you accumulate so much?
Old Mar 29, 2011 | 11:05 AM
Bent's Avatar
Bent
spring run-off, 3' of snow melts and turns to puddles, Ben drives through the puddles and splashes his truck - and stuff that should stay dry winds up getting wet.
