i need help picking a programmer
Old Mar 30, 2011 | 09:49 PM
ah21283's Avatar
ah21283
Default i need help picking a programmer
i have a 2003 dodge ram 1500 5.7 hemi, and i need a good programmer with good horse power gains and the ability to tune my truck, shift points etc. looked at diablo and they say they make em for the 2005- hemi, not the 03.
i have a power pup but bully dog screwed me over on it, i need some advice!
Old Mar 31, 2011 | 11:42 AM
dodgeboy1979's Avatar
dodgeboy1979
superchips 3865 will give you what you need.
Old Mar 31, 2011 | 12:53 PM
NHHEMI's Avatar
NHHEMI
I am not a tuner guy. Don't use them or believe in using them so I can't say use brand XYZ. However just make sure the tuner will work on the 03. At least at one time they had different tuners vs newer trucks. Maybe they have changed that and one tuner will do the 03 at the same time.
Old Mar 31, 2011 | 07:29 PM
lxman1's Avatar
lxman1
Site Moderator
The 03 is a one year only set-up as far as using a separate PCM and TCM.
The Predator will support the 03 but may be limited on the trans tuning, I'm not 100% sure.
http://www.diablosport.com/index.php...isplay&pid=150
I would go to the RAM FAQ section and read thru both the Diablosport and Superchips threads for much more info.
Old Mar 31, 2011 | 07:55 PM
superdak05's Avatar
superdak05
sct, is your choice, get intouch with hemifever.com, aka sean. he knows his stuff,
Old Apr 1, 2011 | 01:39 AM
eric41191's Avatar
eric41191
Diablo trinity is the mack daddy tuner, has the most ability to monitor tunes and actually see the variants in real time.
Old Apr 1, 2011 | 08:57 PM
HemiLonestar's Avatar
HemiLonestar
Sean says you can't tune an 03 hemi with SCT, has to be SC or DSP. Mild mods, 3865 will do the trick (but no trans options). Need to go custom? DSP. DSP does have its limitations on the 03's as well though. You will not be able to adjust your speed or rev limiter (04 & up are golden). Sucks having the bastard year lol.
Old Apr 2, 2011 | 02:06 AM
ah21283's Avatar
ah21283
hahaa yes, the bastard year! what if i get a 2004 ecu and tcu?? will that do the trick? and is that as simple as it sounds? do i just buy the ecu and tcu and have the 2003 one replaced?
Old Apr 2, 2011 | 11:32 AM
HemiLonestar
I know Weed converted his 04 to an 05 setup, I imagine you would need the entire underhood harness and the PCM/TCM module and just match pinouts. Do a search, I'm betting someone has done it with an 03. There is a guy who put a 2003 hemi setup into a previous gen Dakota and made it work. He was talking about converting to the newer setup. Don't know if he did or not.
Old Apr 3, 2011 | 12:19 AM
lxman1's Avatar
lxman1
Site Moderator
I would go to the 05 set-up if upgrading. More trans support.
