Power Steering Question
Old Apr 1, 2011 | 05:02 PM
cfd303's Avatar
cfd303
Default Power Steering Question
I drive my truck and I have been noticing that the steering feels almost non-responsive? Or like the front end steering components (execpt steering wheel) wanders. There doesn't seem to be any freeplay.
Driving around today I notice for the first time after making a turn the truck didn't try and straighten itself out when I let go of the wheel. It kept making a turn. Ya know when the steering wheel will spin the opposite direction by itself? Never noticed this before where I had to turn the wheel the oposite way.
Am I just loosing my mind or is this normal?
Thanks
Old Apr 1, 2011 | 05:03 PM
cfd303's Avatar
cfd303
I should have added I have checked the p/s fluid and it is on the full mark.
Old Apr 1, 2011 | 08:32 PM
Gone Fishin's Avatar
Gone Fishin
Mine started acting the same way last year, and pump was getting a growl to it.
changed the atf+4 in it and all has been great----it just gets worn out after a while
Old Apr 7, 2011 | 12:51 PM
cfd303's Avatar
cfd303
Default How TO?
I suppose w/132,000 miles it will do that. Is it difficult to do? I would like to do it myself and save a few hundred bucks, would any special tools be needed.
Is there any certain brand I should look for? Auto parts store is getting $60 + $25 for core and it also says to replace the filter at $22.
Thanks
Old Apr 7, 2011 | 12:56 PM
MikeHTally's Avatar
MikeHTally
I don't think there is a filter in the power steering. What core? It's unlikely the pump is bad, although it could be. Your description sounds more like an alignment issue, specifically the caster.
Old Apr 8, 2011 | 02:07 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Could also be the rack and pinion internally giving out. With no component ply like in the BJs and wheel bearings, good pressure on the pump and a good alignment, the R&P is where i would look next
Old Apr 8, 2011 | 03:05 PM
cfd303's Avatar
cfd303
Talked to a local alignment shop, first thing he said was ball joints. is there a way to diagnoise that?
Old Apr 8, 2011 | 03:13 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
They should have shown it to you if they feel the BJs are bad. But you can lift the truck and pull the tires back and forth and up and down.
Old Apr 8, 2011 | 03:25 PM
cfd303's Avatar
cfd303
My bad. I just made a phone call to them. I was wondering if there was something I could do to check them before I spend more money.
Thanks
Old Apr 8, 2011 | 08:22 PM
Gone Fishin
The fluid change is fairly straight forward, just makes a real mess and you need 2 people to do it.
As far as the pump goes, I wouldn't immediately condemn the pump
You don't have a rack, if your driving a 2500 it should be a reticulating ball type with a solid front axle.
As far as I know, there is no filter either.
I suggest you get your hands on a factory service manual (FSM), to see answers to your questions, as it explains it way better than I can do here.
I believe Weed may have on you can download for free.
If you do opt to change the fluid, use a good quality synthetic from royal purple, of mobil one or amsoil, they're better quality and last longer
As far as Ball Joints, have the shop SHOW you that they are in fact worn out, and loose. They can be a real PIA to do yourself. You can get the press at advance auto for free rental, but $180 deposit. The ball joints can be anywhere from 0 degree up to 1-1/2 degree offset for alignment correction
If you're mechanically challenged---let the shop do them
