Rear End Ratios
Old Apr 2, 2011 | 04:50 PM
Cthulhu's Avatar
Cthulhu
Default Rear End Ratios
Heya..
Okay, so I've owned my truck almost a year. I understand that a 4.10 rear end requires more RPM for similar road speed as a 3.73. The 3.73 gives better fuel mileage unless you are towing heavy loads from what I've been told.
I do notice however that people change between 4.10 and 4:10. Which is correct?
I would assume that 4.10:1 means the engine turns over 4.10 for every 1 of the rear axel with no reduction in the tranny.
4:10 would mean 4 turns of the engine (or axel) would result from 10 turns of the axel, or engine with no reduction in the tranny.
Which is correct, or am I missing the ballpark?
Old Apr 2, 2011 | 06:06 PM
HammerZ71's Avatar
HammerZ71
4.10 : 1 is actually correct, although the 1 is almost always assumed and not used. It is the amount of times the driveshaft spins per single tire revolution.
Although there is a general thinking that the lower the numerical gearing, the better gas mileage you will attain by virtue of your RPMs being lower at a given speed.
However, in real world driving this is often not the case. Because you turn more RPMs with less throttle, most people see a modest gain in city (stop & go) driving, while only seeing a modest loss while cruising on the highway.
It's not unheard of to gain as much as 2 mpg in city driving with as much as 4.56 gears, although you'll usually give about the same amount back at high speeds on the interstate.
Of course, when determining a re-gear, it's probably more important to consider what your EFFECTIVE GEAR RATIO would be after a gear swap...
Old Apr 17, 2011 | 08:25 PM
Plainbroke's Avatar
Plainbroke
Really wish I could find a set of the factory 3.91s for my 02 to see if it will help with mpg the 4.7L seems to need all the help it can get to move these trucks down the rode.
Old Apr 17, 2011 | 08:41 PM
HammerZ71's Avatar
HammerZ71
Hell, I had my stock 3.92s sitting in a box in storage until just before x-mas, I finally got tired of moving the heavy a$$ box everytime I went in there to look for something, not to mention I coulda used some extra x-mas cash. Sold the set (front & rear) for $125 + 25 shipping...
Not to **** you off, but I played in a golf tourney today across the state and rode with the guy I partnered with in his '02 4.7 QCSB 4x2 Ram and according to the overhead got 19.3 mpg on the 155 mile round trip (mostly highway). I dunno what gears he has although I'm sure they are stock, I'll have to ask him if they are 3.55 or 3.92 if he even knows. I don't think he has a single mod and has big time soccer mom tires on it, probably about 31.5-32" on the factory 17s...
Old Apr 17, 2011 | 09:24 PM
Lowrider82's Avatar
Lowrider82
Thats what i get hwy in my 08 4.7 with 3.92. hell i have done more on the hwy especially after the spark plug change, oil change (RP), and a few other misc.. stuff. no mods. this is of course my overhead display,which is about a half a gallon to a gallon off at times.
Old Apr 17, 2011 | 09:41 PM
That1guy's Avatar
That1guy
I would kill for 19 mpg from my 02 4.7. My 4wd barely gets 13mpg anymore and its stock with 3.92's.
