Old Aug 17, 2015, 12:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Problem Guides
Print Wikipost
Help Really Bad Odor Coming from engine
Old Dec 5, 2010 | 01:32 PM
jmola's Avatar
jmola
Exclamation Help Really Bad Odor Coming from engine
Hi Im new to this forum. I have a 2004 Ram 2500 with 28,000 miles. There is a really bad odor coming from the engine its like a strong burning chemical smell. The dealer checked it and could not figure it out they verified the smell but could not find the source. They claimed it was possibly the new exaust head that they replaced and needed to burn off the film that is on it. I have put on many mile since and its getting worse. I had to stop driving it due to the fact the odor was causing me to get headaches. Last year in the winter I noticed a neon yellowish greenish color coming from the exaust. Dealer said it was nothing. I drive the truck mostly in the winter months so it sit through the summer. My extended warranty is up in a few months so i need to figure this out soon and the deal seems to brush it off. Any suggestions or feed back would be great. Thanks In advance.
Old Dec 5, 2010 | 07:03 PM
MontanaRAM's Avatar
MontanaRAM
coolant burnoff would be my guess.
Old Dec 5, 2010 | 07:41 PM
That1guy's Avatar
That1guy
I also say coolant burn off. Inhaling antifreeze would be bad.
Old Dec 5, 2010 | 07:47 PM
freestyledude's Avatar
freestyledude
is your oil milky? Sounds like a head gasket to me
Old Dec 6, 2010 | 08:57 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Bad catalytic?
Old Dec 6, 2010 | 12:51 PM
BWhelan's Avatar
BWhelan
x3 because of the "chemical" comment.
Would be my guess as well...
Old Dec 6, 2010 | 12:55 PM
MikeHTally's Avatar
MikeHTally
When I first got my Magnaflows, they smelled pretty bad. I figured it was some sort of chemical used in the manufacturing process. It subsided in a week or so, I think. It's been a while since I did that.
Old Dec 6, 2010 | 01:09 PM
BWhelan's Avatar
BWhelan
Maybe to what Weedahoe said, check your Cat.
Now knowing you have aftermarket exhaust, I would make sure to check all the connections too. Do you feel like you're losing power?
Old Dec 6, 2010 | 01:38 PM
jmola's Avatar
jmola
Thanks for the response. Im going to look in to all suggestions. Since I had the exaust fixed the truck runs great just the smell is terrible. You can smell it 10 feet away from the truck when its parked. I belive it started prior to changing the exaust prior to then the smell was not as strong and it smells like lawn fertalizer so at first I thought it was coming from my neighbor since he is a landscaper. but since I had the exaust manifold replaced it is much stronger. I hardly drove the truck this summer so I did not realize that it was the truck that was causing the odor. Thank for everyone's help.
Old Dec 6, 2010 | 01:46 PM
boopadoopa's Avatar
boopadoopa
Maybe vandalism? An animal in engine compartment? Not sure of the smell but unless its the CAT there should be no other chemical smell the engine will produce.
