What is the name of the seal - where to buy it
Old Apr 4, 2011 | 06:45 AM
peecee78's Avatar
peecee78
Default What is the name of the seal - where to buy it
2002 4.7 RAM 1500 SLT
Hello
Finally i found out that my driver side head is cracked - the engine is striped and now i wait for one head to be send to me from USA (i live UK). While stripping the engine i damaged one of the seals and can not find replacement - it is the orange one (triangle shape at the top of the engine block + picture show that seal yellow).
Uploaded with ImageShack.us
Please can you direct me with seal number or link to place i can buy it online
THNX
Old Apr 4, 2011 | 09:13 AM
JDG103's Avatar
JDG103
dont know the name of it...but if i was you, i would get some RTV and make my own gasket IMO
Old Apr 4, 2011 | 10:07 AM
slimvela's Avatar
slimvela
EDIT: I forgot that there is a production change for the 2002 4.7's.
If yours was built before 5/13/2002 it is the one piece gasket plate.
If it was built 5/14/2002 or later then you can in fact change just the triangular shaped gasket, as well as the 2 circle gaskets, by themselves.
As you can see both kits will also come with a Front Crankshaft Seal. So you need to figure that out the production date of the vehicle prior to ordering.
Although I have heard that either will work, was told it was easier/cheaper to produce the newer version rather than the plate gasket setup.
For vehicles built before 5/13/2002 the orange/yellow gasket is actually bonded to a metal plate that is also bonded to the other gaskets, orange/yellow circles and larger gasket. They form what is called the timing cover gasket. Comes as a kit, includes the crankshaft seal as well, which is pressed into the cover. Most U.S. auto parts retailer should carry the kit.
