Oil advice
Old Apr 5, 2011 | 11:49 AM
timekop's Avatar
timekop
Default Oil advice
I was traveling out of state the other day and my temp gauge went straight to "H". I immedialtely pulled to the shoulder on the interstate and turned off the engine. I popped the hood and found anti freeze all over the underside of the hood. I let the engine cool before I restarted and limped off the interstate, about a mile, where I called for a tow.
Q. Should I change the oil due to the engine heating up? I run Castrol Syntec in it. I have a few hundred miles to go before the next oil change.
By the way, my radiator resovier was cracked on the bottom.
Old Apr 5, 2011 | 11:55 AM
HammerZ71's Avatar
HammerZ71
I don't think that short a period would degrade an engine oil, but if it's that close to needing to be changed, I'd be more inclined to go ahead and do it now.
See a lot of '02s with failed radiators lately.
Is this a 4.7 engine? If so, it REALLY doesn't like to overheat. Keep an eye out for coolant loss as this would indicate that you lost the head gasket or worse, cracked a head(s)...
Old Apr 5, 2011 | 11:58 AM
kx250frider617's Avatar
kx250frider617
I dont know if you got it fixed yet, but I wouldn't pay anyone to change out a radiator. It is super easy and its nice to keep whatever cash we have in our pockets.
Old Apr 5, 2011 | 11:59 AM
kx250frider617
scratch that, you said reservoir.
Old Apr 5, 2011 | 05:55 PM
timekop's Avatar
timekop
Checked the oil and it didn't look burned..has a light brown color to it. I think I'll let it go a few more miles.
Old Apr 5, 2011 | 07:17 PM
dirtydog's Avatar
dirtydog
Moderate User
Well, if Mobil 1 is good up to 1600*F, I'd think Castrol Syntec can withstand a mild bump in temp. I'd worry about heads warping before the oil being torched.
HERE is a link to Mobil 1's Turbo charger oil test
