cruise control question
Old Apr 4, 2011 | 09:04 AM
techguy_09's Avatar
techguy_09
Question cruise control question
hi all, i tried searching the forums but im unable to find any answer on this. recently got the front hub bearing replaced. but now i notice that when im in park my cruise will turn on, but when im driving it turns off.
thought maybe a brake switch or the actual switch, i have the hemi
thanks to all
Old Apr 4, 2011 | 09:46 AM
xxxmoparmaniaxxx's Avatar
xxxmoparmaniaxxx
Default Cruise issue
I have an 04 ram 1500 that has the exact same problem....ideas??
Old Apr 4, 2011 | 09:50 AM
techguy_09's Avatar
techguy_09
oh and i checked for trouble codes and none have come up
Old Apr 4, 2011 | 12:49 PM
Dodge Leaks's Avatar
Dodge Leaks
Default Cruise Control Problem
I had the exact same problem, and it took awhile to figure out. Apearantly the stock anti-skid brake sensors had a problem with my aftermarket hubs. The shop replaced the sensor with a different one (not sure what the difference was) and the problem went away.
NNY
Old Apr 4, 2011 | 03:04 PM
techguy_09's Avatar
techguy_09
ok so more info on this, when im at a stop or in park when i hit cruise on it will come on then go off, never stays on. when the truck is in motion. hitting cruise on doesnt nothing, no light or anything
Old Apr 4, 2011 | 04:53 PM
lxman1's Avatar
lxman1
Site Moderator
Bad front wheel sensor. I just went thru this. Had a new hub put on under warranty and when I got it back, the cruise wouldn't even come on. The new Dodge sensor was bad. They hooked my old one up and it worked fine, so they replaced the sensor again from another new hub.
Old Apr 4, 2011 | 05:00 PM
techguy_09's Avatar
techguy_09
well i just go the hubs replaced. does that mean the sensors that came with them are bad? and do they sell just those sensors? that you know
Old Apr 4, 2011 | 10:16 PM
techguy_09's Avatar
techguy_09
well on the way home tonight cruise light came on when pressed and worked for about 20 miles. i wish it was just a steering wheel sensor thats easy to change
Old Apr 5, 2011 | 12:10 PM
techguy_09's Avatar
techguy_09
im gonna see if the guy who changed them has the original abs sensor i can put back on and we will see if thie problem goes away
Old Apr 5, 2011 | 12:44 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Interesting. I wanna see a resolution to this
