Ram cutting out at low acceleration between 45-65mph...
Old Apr 7, 2011 | 09:24 AM
e44458's Avatar
e44458
Default Ram cutting out at low acceleration between 45-65mph...
My 2003 4.7 Ram is cutting out at low acceleration, cruising speed, at around 45-60mph. This is intermittent and I am not able to reproduce it all the time. But, when it does occur, it happens in the 45-65mph range.
If I accelerate harder when it cuts out, it drives right though it and stops cutting out. If I have my foot off the gas, I don't feel it cutting out. If I drive harder than normal through to 65-70mph, it never cuts out.
I replaced the TPS, it was cheap enough and I gave it a shot with that. It did not fix it.
There are no error codes right now.
One other thing, I have called this problem, hesitation, etc... But, I really think it is cutting out more than it is hesitating. It is hard to describe, I guess.
Any help is much appreciated!
Old Apr 7, 2011 | 10:05 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
What maintenance has been done to the truck since you have had it?
Old Apr 7, 2011 | 10:19 AM
e44458's Avatar
e44458
New plugs at around 75k. Truck has 109k now.
Regular oil changes, air filter just changed.
Haven't touched fuel filter, original ignition coils, and plug wires.
Transmission oil looks good enough, not burnt up and is not low.
Evap canister replaced. TPS replaced. Battery cables replaced. Other than this, it has always run pretty darn good.
Currently no error codes.
Old Apr 7, 2011 | 10:34 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You are due for another plug change. Trans oil should have been changed by now also. is it a certain speed or could it be a certain RPM?
Are you using the OEM air housing filter setup?
Old Apr 7, 2011 | 11:10 AM
e44458's Avatar
e44458
It certainly seems to be through a certain speed, because it has never happened at speeds less than 40mph and never over 65mph.
Should I replace the plugs and wires or just plugs?
Should I go ahead and change trans fluid or do a partial change? Filters?
Yes, I am using the OEM air filter housing.
Old Apr 7, 2011 | 11:54 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Plugs and trans filter change I dont think is the issue but just good maintenance to do since it needs it anyway. As for the OEM air filter housing, pick a dry dust free day and disconnect the air filter tube from the mouth of the throttle body and do a quick drive on the road to see if it still does it. You are mainly checking for air restrictions to the engine.
Old Apr 7, 2011 | 01:48 PM
e44458's Avatar
e44458
So, you think it could be something obstructing from the intake to the airbox? I will check that out? Anything else to check when I get home?
Old Apr 7, 2011 | 09:00 PM
gcburkett's Avatar
gcburkett
Is there any way the torque convertor is slipping? You don't see any acceleration issues in 1st or 2nd or and maybe 3rd gear.
Old Apr 7, 2011 | 11:44 PM
05HemiRam1986's Avatar
05HemiRam1986
EGR valve? Mine had similar problem, rpm related though around 1600-1700 had a miss Dealer replaced it under warranty at around 70k km
Old Apr 8, 2011 | 08:21 AM
e44458's Avatar
e44458
Ok, so I drove the truck for a while last night and to work today and here is what I can tell. The missing/cutting out happens in the 1400-1800 rpm range and it happened from 48-70mph. It was not constant, but often when I am in that rpm range and give it a little gas, I start to feel the missing/cutting out. If I get the rpm's above 2000, then I do not feel it.
Also, I checked for obstruction in and around the airbox and intake and it is clear.
Thoughts?
