Ram cutting out at low acceleration between 45-65mph...
Old Apr 8, 2011 | 08:22 AM
e44458's Avatar
e44458
Sorry, I hadn't read these new posts before I replied. Thanks for the information.
Old Apr 8, 2011 | 11:26 AM
e44458's Avatar
e44458
Does the 2003 have an EGR?
Should I be looking at the IAC?
Old Apr 8, 2011 | 01:50 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
2003 does not have an EGR. Sorry.
Old Apr 8, 2011 | 02:19 PM
e44458's Avatar
e44458
Since it doesn't have an EGR and I am noticing it being within an RPM range, does that lead you to anything else to look for?
Old Apr 8, 2011 | 11:53 PM
undertow's Avatar
undertow
P 0335....crankshaft position sensor circuit
Old Apr 11, 2011 | 09:38 AM
e44458's Avatar
e44458
Could the crankshaft sensor be failing without a check engine light showing up?
Old Jul 17, 2011 | 02:53 PM
terryjk58's Avatar
terryjk58
I've got an 02 Durango and having the same problem, and driving me CRAZY! This is the first post I've seen with the same problem, except mine does it right around 30-40 mph right at the point between accelerating and letting off. At first I thought it was the transmission (automatic), but I don't think it is. I've replaced the air filter, and did what weedahoe posted, but no results. I'm gonna try replacing plug wires next and see what that does. If it works , I'll let you know. In the mean time any suggestions would be appreciated. Thanks.
Old Jul 17, 2011 | 05:20 PM
lxman1's Avatar
lxman1
Site Moderator
Plugs/coil boots. Sounds like it is arcing under low rpm/heavy load. Be sure to use dielectric grease on the boots where they go onto the plugs.
Old Jan 18, 2012 | 02:43 PM
terryjk58's Avatar
terryjk58
And now since the weather has gotten cooler, it doesn't do it at all any more.....really weird.....
Old Jul 18, 2012 | 01:55 PM
detailedEye's Avatar
detailedEye
Sorry to reply to an old thread, but was there a resolution for this? I searched but didn't find anything else like this.
I'm having the same problem with an '04 Dakota (4.7L) that I bought recently. I got the car dealer to replace the IAC, TPS and clean the intake and throttle body because the RPM's were bouncing at startup. Fixed bouncing issue but not the cut out. I replaced the plugs last weekend with copper NGK's but the issue remains.
Took the truck to tranny shop and they believe it to be intake or air/fuel related. They're currently cleaning the top end & valves just in case the stealership missed something.
Besides the cutting out in the 45-65 mph range it also idles a little rough. I've noticed the cutting out is worse on really hot days. We just had a 100 degree day in the Minneapolis metro & it was pretty bad on the highway @ 65 mph.
Any thoughts would be great!
