cam question?
Old Apr 8, 2011 | 05:13 PM
badnews's Avatar
badnews
Default cam question?
can i run a 261 comp cam with all the stock valves and springs or do i have to change them to a bigger size.
Old Apr 8, 2011 | 08:25 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You mean a 260 cam. You must change the valve springs out to 16 6.1 exhaust springs, use 6.1 pushrods, a new cam and crank bolt, and maybe new head gaskets and head bolts depending on you do it.
I've got a tool for sale to change the valve springs and also another tool to use compressed air to keep the valves up if you change the springs with the heads on the block.
Old Apr 8, 2011 | 08:42 PM
HammerZ71's Avatar
HammerZ71
Yep, recommend Comp Beehive, Manley or Mopar 6.1 springs. The Manley's are probably the best but are by far the most expensive. The Mopars are at least as good as the Comps if not better and are a lot cheaper. Pushrods recommended but not necessary, and don't forget to do the retainers with the springs...
Old Apr 8, 2011 | 10:03 PM
lxman1's Avatar
lxman1
Site Moderator
CompCams springs are good. I have used them in several engines. I haven't heard anything bad about the Mopar springs either.
Old Apr 9, 2011 | 05:41 PM
chefred112's Avatar
chefred112
i hope they've changed how they make the comp springs..I've seen several break in different rams..one which the hemi had to be replaced..
Old Apr 10, 2011 | 12:39 AM
lxman1's Avatar
lxman1
Site Moderator
HMMM, My Mustang often sees 6500rpm with no spring issues. My old 460 with a comp 268 never had any issues either.
NASCAR uses them as well. 9000rpm +
Maybe they had some Dodge spring issues. I don't know.
