Trans fried!
Old Apr 13, 2011 | 12:55 PM
ccgRAMrod's Avatar
ccgRAMrod
Default Trans fried!
Anyone ever fry their transmission in a 2003 Ram 2500 with a 5.7? I just found out mine's fried and on it's way out the door! Good thing I decided to have it checked before I went out West with it pulling a trailer. That may have sucked!
Old Apr 13, 2011 | 02:40 PM
That1guy's Avatar
That1guy
From what I understand the 545RFE is pretty good. Better than what the 2 gens had. What happened to fry it? Do you pull a lot? I assume it has a good cooler on it?
Old Apr 13, 2011 | 02:55 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Lots of guys have had trans issues. But no more than a normal amount of guys. I mean, it is an 03 you got. How many miles are on it BTW?
Old Apr 13, 2011 | 05:02 PM
ccgRAMrod's Avatar
ccgRAMrod
I have the stock Trans cooler on it from the factory and was told that was good enough for it. I have 64,500 miles on it, and yes I just use it to pull mostly. I used to pull a four place inclosed trailer in winter but that was the most. Im having the shop that is going to do the work on it beef it up as best as possible. Do you think I need another trans cooler on it? I bought a Mag tech trans pan for it with extra capacity. What are your thoughts?
Thanks
Old Apr 13, 2011 | 10:15 PM
Ben D.'s Avatar
Ben D.
**** happens man. Although I read on a lot of forums and I gotta be honest it doesn't seem to matter what brand, if the half ton trucks get used for towing a lot it seems to lead towards issues down the road.. Not big ones but certain things that someone who uses their 1500 for occasional work wouldn't deal with.
Although kudos to you for not making a thread bitching about how much your truck sucked or something.. Cheers
Old Apr 14, 2011 | 07:22 AM
ccgRAMrod's Avatar
ccgRAMrod
No, it doesn't pay to complain since in my book all brands suck in their own way. It is a mechanical machine and isn't perfect so things like this do happen. At least it should be like new now!
Old Apr 14, 2011 | 09:23 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
There are several sites out there that specialize in 545rfe build-ups that could potentially be a lot better than a local chop that does general repairs or rebuilds
Old Apr 14, 2011 | 09:32 AM
ccgRAMrod's Avatar
ccgRAMrod
The shop I took it to is a custom trans shop that specializes in trans repairs and building of trans for commercial, race, and regular use. They come highly recommended from other shops by me.
http://www.autotransdesign.com/
You think I need another trans cooler installed besides the stock one?
Old Apr 14, 2011 | 10:16 AM
redruMHauler's Avatar
redruMHauler
just changed one on one of our 2005's (190K miles) driven like it is stolen
cost 740$ dropped it off Thursday am picked it up Friday afternoon
5th tranny this co has done for us have only had one problem, one had a wire broke on the harness inside the tranny took a while to figure out but was a free fix
Old Apr 14, 2011 | 10:17 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can get the 1 ton cooler but the bigger Q is do you need it? And the only way to answer that is to watch and know what your trans temps are when you are towing. You also have 75-140w gear oil in the rear diff for towing right?
75-90 is for normal usage and 75-140 is for towing
