Hid's causing static in my radio.
Old Apr 14, 2011 | 10:56 PM
Kingnothing's Avatar
Kingnothing
Default Hid's causing static in my radio.
I just put in a set hid's from hidextra in my fog lights and now there are a couple of a.m stations that don't come in anymore, not really a big deal I listen to my iPod about 99% of the time but my ocd kicks in when something on my truck doesn't work right. Anything I can do? My truck is an 2004 if that matters.
Thanks
Old Apr 15, 2011 | 08:02 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
A very common issue with HID ballast. A ballast is a very strong transformer than emits EMI/EFI and causes the interference. Only thing to do is try to relocate them and try a cleaner, more solid or better ground also.
Old Apr 16, 2011 | 11:02 AM
Kingnothing
Its really not that big of a deal. I listen to my Ipod most of the time.
I might try one these
http://www.sonicelectronix.com/item_...S-12.html#tabs
or these
http://www.retrosolutionsllc.com/ser...LER-HID/Detail
Old Apr 17, 2011 | 09:11 PM
KDSR's Avatar
KDSR
You can also try wrapping the ballast in foil for a quick and cheap solution.
Old Apr 17, 2011 | 09:24 PM
Matt99's Avatar
Matt99
i might try the foil thing. i cant see how it will work but its a cheap and easy attempt
mine do the same though. If I am idling its so bad that I cant even hear some of the voices on the talkshows
Old Apr 17, 2011 | 10:35 PM
KDSR's Avatar
KDSR
Copper tape will also shield EMI/EFI.
Old Apr 17, 2011 | 11:39 PM
Brandon Anderson's Avatar
Brandon Anderson
Where did you place your ballasts?
Old Apr 18, 2011 | 10:23 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Years ago, come manufactures would make their radio chassis out of copper to reduce or stop EMI/EFI.
But we all know what happened to the price of copper since then
Old Apr 18, 2011 | 10:37 PM
Kingnothing
I put mine on the support bracket right next to the fog light.
Old Apr 19, 2011 | 07:21 AM
KDSR's Avatar
KDSR
When the prices of copper first started to sky rocket, the theft of wire from light standards was rampant around these parts. I remember a couple years back one guy electrocuted himself and died trying to steal some.
