Spindle Lift DIY/Shackle Install
  #31
Old 06-12-2011, 07:01 AM
Matt99's Avatar
Matt99
Matt99 is offline
I had to get mine pressed out as well. The shop said their 100 ton (or something like that) press usually never hesitates but did with them, so I was not going to get them with the dang hand turned press
The upper isnt replaceable, you have to get entire UCAs. I think they are only 110/each though.
  #32
Old 08-31-2012, 02:38 AM
Jason Hendrix's Avatar
Jason Hendrix
Jason Hendrix is offline
I want to put a 3 in spindle lift on my 2006 dodge ram 1500 but I am unsure what brand to buy so what brand did you buy or where did you get them
  #33
Old 08-31-2012, 10:10 AM
08HEMI1500's Avatar
08HEMI1500
08HEMI1500 is offline
There's a seller on ebay that sells them. But they are from a place called airbagit. That's if you only want the spindles though. If you want a whole kit thats a different thread. And FYI the OP of this thread is no longer on here as he bought a new truck (Ford).
  #34
Old 08-31-2012, 10:54 AM
team_realtree's Avatar
team_realtree
team_realtree is offline
I got 3" spindles for my 06 1500 from a seller called pricebusterchris on eBay, haven't put them in yet but they look high quality and they shipped fast even to Canada.
  #35
Old 09-16-2014, 04:29 AM
greyghost63's Avatar
greyghost63
greyghost63 is offline
did the spindle lift offset the front tires any?
  #36
Old 09-16-2014, 11:50 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Spindles don't offset (make it stick out or in)
Lift singles don't change the suspension geometry either as all they do is place the tire hub lower in the spindle which raises the truck
Lift springs will cause a more stiff ride
  #37
Old 09-17-2014, 12:34 AM
CopenghagenHemi22's Avatar
CopenghagenHemi22
CopenghagenHemi22 is offline
Is this possible with 4wd? and also your truck was squatting if, I do this I would want a level finish.
Can anyone please help me on this.
  #38
Old 09-18-2014, 11:13 AM
team_realtree
Both my "airbag it.com" and "max trac suspension" spindles pushed my front tires out around 1".
Those are the only two your gonna be buying unless your wasting money on cst spindles.
It's clear to see because I have a very tight parking spot at work and when parked dead parallel against the line the front tires hang over and backs don't
Quick Reply: Spindle Lift DIY/Shackle Install
