Any Ideas? Help!
Old Apr 18, 2011 | 08:26 PM
TxRam03's Avatar
TxRam03
Default Any Ideas? Help!
I was on my way to work and my truck sputtered and shut off. The check engine light came on about a month ago. Trouble codes P0340, p0344 suggested a camshaft sensor issue. I replace both Camshaft and crankshaft sensor and still will not crank. It turns over but will not start.
Old Apr 18, 2011 | 09:15 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site. I will check the codes tomorrow at work. In the mean time maybe someone else can help out
Old Apr 19, 2011 | 10:37 AM
bamataco's Avatar
bamataco
PO340 is No cam referance signal from the CMP sensor at the PCM.
Old Apr 19, 2011 | 10:51 AM
Matt99's Avatar
Matt99
your thread title says "help" but does not describe a problem or anything in reference to your thread.
Maybe if you included this in your title you would get more help.
Old Apr 20, 2011 | 01:42 PM
TxRam03's Avatar
TxRam03
Does this mean that cam sensor is bad, I replaced both cam & crank sensors. Still having a no-crank problem.
Old Apr 20, 2011 | 01:52 PM
dodgeboy1979's Avatar
dodgeboy1979
Need some info on your truck, what engine are you running and have you done any previous work to it that might help us out a bit.
Old Apr 22, 2011 | 12:58 AM
TxRam03's Avatar
TxRam03
I have a 4.7 magnum I have had the truck for just over a year. I had the timing chain replaced about 8months ago. That has been the only work that has been done to th truck so far. As I said I replaced the crank and Cam sensor last week, with no luck.
