speakers are cutting in and out
Old Apr 21, 2011 | 01:52 AM
floydaces's Avatar
floydaces
Default speakers are cutting in and out
I'm pretty sure its the connection. It's the front two speakers. Or would the problem be behind the radio, its a keenwood.
06 ram 1500
Old Apr 21, 2011 | 04:09 AM
jmgak47's Avatar
jmgak47
Odds are its a grounding issue.
Old Apr 21, 2011 | 06:03 AM
Brandon Anderson's Avatar
Brandon Anderson
If it's aftermarket in a CANbus equipped truck, the first place I would check is behind the radio. Does the cut-out occur at all volume levels in all speakers?
Old Apr 26, 2011 | 02:05 PM
08arhemi's Avatar
08arhemi
Ditto...I did my install myself a year ago and over the winter had a speaker that went in and out as it saw fit. After two warranty claims for different connectors, I found a bad connection inside a crimp. Took me an hour with a meter maid and tearing off door panels, but I found it! Long story short, check your connections...
Old Apr 27, 2011 | 09:16 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Agreed. I also have has a wire rub on the door frame until it just barely rubbed through the speaker lead insulation and caused a short which caused the speaker to cut in and out
