suspension sag, question
Old May 3, 2011 | 12:08 AM
devanwon's Avatar
devanwon
it has about 3/4 tank now, ill check it when it gets low.... would that make the whole side lean a bit though?
Old May 3, 2011 | 08:10 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Over a period of time it might
Old May 3, 2011 | 10:35 AM
dirtydog's Avatar
dirtydog
Moderate User
Have you done a carfax report on it to verify there aren't any major accidents on record?
Old May 3, 2011 | 11:55 PM
devanwon's Avatar
devanwon
yeah i have and its clean.... my buddy had a good idea, im going to check the front coils tomorrow and make sure they are seated in the right place that def could cause an issue, also he said check the rear ubolts to make sure they are tight.. i just did and they are so off to check the front tomorrow, ill keep you guys posted.
also i did check all the body mounts/bushings and they are ok, i think i may have something here with the spring thing!!
Old May 4, 2011 | 01:36 AM
Caseys-dodge's Avatar
Caseys-dodge
My truck was an inch lower on the passenger side. I was able to adjust the torsion bars and that set it back level. It sent my alignment out of whack, but I'm certainly putting the 12 month / 12k mi alignment warranty to good use at Pep Boys.
