suspension sag, question
Old 05-01-2011 | 10:12 PM
devanwon's Avatar
devanwon
Default suspension sag, question
ok so i have a 06 ram 2500 mega cab, has the hemi... it is lifted 12" on 41's
(yes i know, lol) anyways i just bought the truck and it has a noticable lean about 1/2inch or so on the drivers side and is consistant front to back. any ideas what could cause this, i looked at everything and nothing is bent or tweaked that i notice, just seems weird that both front and back on on side know what i mean.... so any ideas guys??
Old 05-01-2011 | 10:40 PM
2006RAMHEMI1979's Avatar
2006RAMHEMI1979
I think people used to call that the bachelor lean, or something like that. The weight of the driver and never having a passanger.
Old 05-01-2011 | 10:47 PM
devanwon's Avatar
devanwon
bachelor lean, haha... actually with the drop down steps i have everyone loves to go in it.. and im only 190lbs so not too much strain on the driver side, lol
Old 05-02-2011 | 02:16 AM
Brandon Anderson's Avatar
Brandon Anderson
Was the previous owner only 190lbs? LoL
Old 05-02-2011 | 02:37 AM
Razorhawg's Avatar
Razorhawg
fill the gas tank a lot?
Old 05-02-2011 | 03:07 AM
Brandon Anderson
I would venture that either the previous owner was very heavy, or it's a cheap/improperly installed lift.
Old 05-02-2011 | 11:03 AM
John  M's Avatar
John M
I'm 300 lbs and no vehicle I've ever owned has developed a lean because of it, even my old 2450lb Mirage. If you're fat enough to make a 2500 mega cab lean you're probably in imminent danger of dropping dead and couldn't climb up into it anyway.
Old 05-02-2011 | 11:09 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You could try replacing the body mounts/bushings to see if they are bad due to you stepping up in the truck and sitting in it.
A 26 gal tank does add about 180# of fuel and a 35 gal tank adds about 245#
Old 05-03-2011 | 12:11 AM
Brandon Anderson
I've seen 400-500lb "people" that are still "mobile." It happens LoL I meant it more as a joke though.
Old 05-03-2011 | 12:45 AM
Razorhawg's Avatar
Razorhawg
look at nfl linemen those dudes are 350+ and still run under a 5.0 40 there are some really mobile big guys... but im still sticking with the gas tank thing mine has a lean once in a while also
Quick Reply: suspension sag, question
