Trouble code P0441 help
Old May 11, 2011 | 07:02 AM
zeke83's Avatar
zeke83
Well I found the problem...The 3 way hose connector from the purge valve was broke. The only problem is I cannot find the replacement part online. I would go to a dodge dealer, but thats a half hour away....
The connector is one 1/4" and two 5/8"
Old May 11, 2011 | 07:50 AM
HammerZ71's Avatar
HammerZ71
How did you not see this when you replaced the purge valve???
Old May 11, 2011 | 08:05 AM
zeke83's Avatar
zeke83
Purge valve is up front, this connector is back by the gas tank.
Any idea where I could get a connector like this from? No luck at hardware store or auto stores
Old May 11, 2011 | 08:43 AM
HammerZ71's Avatar
HammerZ71
I'm assuming it's strictly a Mopar part. I can't even find a diagram of it with a part number. I can find the part numbers for the two hoses that come off the purge valve up front, but not the connector you are talking about.
If not the dealer you can try:
DodgeParts.com
111 Bond St
Westbury, NY 11590
1-877-211-4887 Toll Free
Old May 11, 2011 | 09:06 AM
zeke83's Avatar
zeke83
Yeah I could not find it on a diagram either. The connector has odd ball sizes too, so I cant match it up to any standard fittings to try and cob something together.
Thanks again for all the help!
