Truck shakes when I slow down
Old May 4, 2011 | 02:35 PM
jrh883's Avatar
jrh883
Default Truck shakes when I slow down
I have a 2003 1500 quad cab. When I am going over 40 and press on the brake it shakes. Cant feel it as much at lower speeds. It is not the rotors I have already replaced them. What else would cause this?
Old May 4, 2011 | 02:37 PM
nussdawg395's Avatar
nussdawg395
Bad tie rod ends can cause that.
Old May 4, 2011 | 03:16 PM
jrh883's Avatar
jrh883
What could I do to check this?
Old May 4, 2011 | 04:15 PM
HammerZ71's Avatar
HammerZ71
If you replaced them with Mopar rotors, could still be the rotors. I had same issue with ex-wife's Grand Cherokee, new rotors warped almost as soon as I put them on. Went with inexpensive auto parts store set and never had a problem.
To check tie rod ends, lift front tire, look for side/side play...
Old May 4, 2011 | 08:49 PM
pitbull24's Avatar
pitbull24
What shakes exactly? Do you feel it mostly in the steering wheel?
Old May 4, 2011 | 10:02 PM
JDG103's Avatar
JDG103
have you balanced and rotated your tires lately
Old May 5, 2011 | 02:17 PM
Warfire80's Avatar
Warfire80
I had the same problem on my 06. Changed the front rotors and brake pads and no more shakes.
